Введение
This is a quick guide on how to replace the charging port of a Toshiba Satellite E45t-B4204. Replacing the charging port can fix a charging port due to excessive use.
Выберете то, что вам нужно
Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
Remove the back case.
Один комментарий
You didn’t complete the instructions. It ended after you said unplug the charging port housing. The pictures are not clear. Please add red lines or arrows, etc. to show what you are trying to do. It doesn’t show or spell out the next steps to replace it.
