Введение
Use this guide to replace a defective fan and heatsink in a Toshiba Satellite E45t-B4300.
Выберете то, что вам нужно
Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
Remove the four 2mm screws with a Phillips #0 screwdriver.
Remove the two 2mm screws with a Phillips #0 screwdriver.
Use a spudger or your fingers to disconnect the fan from the motherboard.
Remove the fan and heatsink.
