Введение
If the hinges become loose from wear and tear or break, creating hassle when using the computer, on your Toshiba Satellite L305-S5875, this guide walks you through how to access and tighten, or replace as needed, the hinges on your Toshiba Satellite L305-S5875.
Инструменты
Запчасти
Детали не указаны.
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
Starting at the top, gently raise the keyboard enough to remove it from the socket.
Locate the data cable that is connected to the motherboard.
Pull the white ZIF connector towards the screen to remove it.
Pull the black ribbon cable away from the screen.
With the black ribbon cable now disconnected, remove the keyboard from its housing.
Close your laptop and flip it over.
Remove the 13 screws using a Phillips #00 screwdriver.
Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
Congratulations, you may now remove and replace your hinge!
Еще один человек закончил это руководство.
