Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Push the release button to the right.
Hold the release button to the right and lift the battery out of its housing.
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
Starting at the top, gently raise the keyboard enough to remove it from the socket.
Locate the data cable that is connected to the motherboard.
Pull the white ZIF connector towards the screen to remove it.
Pull the black ribbon cable away from the screen.
With the black ribbon cable now disconnected, remove the keyboard from its housing.
3 участников успешно повторили данное руководство.
