Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to remove housing on the base of your Toshiba Satellite L305-S5946. Removing the housing gives you access to the motherboard, processor, power jack, fan, and LCD screen.
Выберете то, что вам нужно
Place the laptop upside-down with the display hinges facing away from you.
Slide the latch for the right battery bay to the right and hold.
Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Slide the hard drive to the left using your fingers.
Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
Pull the RAM card away from the computer.
Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
Insert the plastic opening tool at either end of the strip.
Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
Pry the top of the keyboard loose from its casing using a plastic opening tool.
Gently push the two tabs locking the black ribbon cable.
To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
You may now safely separate the keyboard from the laptop.
Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
Turn the laptop right-side up.
Flip open the laptop so that the screen faces you.
Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
Gently pull on the two black tabs locking the white ribbon cable in place.
Pull the white ribbon cable towards you to remove it.
Use tweezers to remove the connector that has the blue, red, black, and white wires.
Use a plastic opening tool to pry the laptop's upper casing off of its lower casing. Move the opening tool around the sides of the case to help separate them.
Еще один человек закончил это руководство.
