Введение
Use this guide to replace the battery in your Toshiba. If your battery is damaged or won't hold a charge, it should be replaced.
Инструменты
Запчасти
Детали не указаны.
Turn the laptop upside-down.
Position the laptop so that the display hinges are facing away from you.
Slide the right battery bay latch to the right and hold.
While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Почти готово!
Заключение
