Введение
Use this guide to replace the keyboard in your Toshiba Satellite L305-S5946. Unresponsive or sticky keys are good indicators that the keyboard should be replaced. You must remove the keyboard to access the base housing.
Инструменты
Запчасти
Детали не указаны.
Turn the laptop upside-down.
Position the laptop so that the display hinges are facing away from you.
Slide the right battery bay latch to the right and hold.
While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
Turn each screw until you hear a click.
Slide the hard drive to the left using your fingers.
Insert a plastic opening tool under the right side of the hard drive.
Carefully lift and remove the hard drive.
Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
Turn the screw until you hear a click.
Insert the plastic opening tool into the indent and lift to remove the RAM cover.
Use your fingernails to push the white and silver retaining clips away from each side of the RAM card.
Use your fingers to gently pull the RAM card away from the computer.
Repeat step 9 to remove the other RAM card that may be installed.
Turn the laptop right-side up.
Lift open the laptop so that the screen faces you.
Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
Insert the plastic opening tool at either end of the strip. Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
Use a Philips #00 screwdriver to loosen and remove the two 3-mm screws at the top edge of the keyboard.
Use a plastic opening tool to pry the top of the keyboard loose from its casing.
Gently push the two tabs locking the black ribbon cable.
Slide the keyboard toward the screen to remove the black ribbon cable from the motherboard.
You may now safely separate the keyboard from the laptop.
