Введение
Use this guide to remove or install a motherboard on your Toshiba Satellite L305-S5946. It will be necessary to remove the motherboard to replace the GPU. This guide also acts as a prerequisite for the processor and cooling fan installation guides.
Инструменты
Запчасти
Никакие детали не требуются.
Turn the laptop upside-down.
Position the laptop so that the display hinges are facing away from you.
Slide the right battery bay latch to the right and hold.
While holding onto the latch, use a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
Turn each screw until you hear a click.
Slide the hard drive to the left using your fingers.
Insert a plastic opening tool under the right side of the hard drive.
Carefully lift and remove the hard drive.
Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
Turn the screw until you hear a click.
Insert the plastic opening tool into the indent and lift to remove the RAM cover.
Use your fingernails to push the white and silver retaining clips away from each side of the RAM card.
Use your fingers to gently pull the RAM card away from the computer.
Repeat step 9 to remove the other RAM card that may be installed.
Turn the laptop right-side up.
Lift open the laptop so that the screen faces you.
Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
Insert the plastic opening tool at either end of the strip. Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
Use a Philips #00 screwdriver to loosen and remove the two 3-mm screws at the top edge of the keyboard.
Use a plastic opening tool to pry the top of the keyboard loose from its casing.
Gently push the two tabs locking the black ribbon cable.
Slide the keyboard toward the screen to remove the black ribbon cable from the motherboard.
You may now safely separate the keyboard from the laptop.
Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
Flip open the laptop so that the screen faces you.
Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
Gently pull on the two black tabs locking the white ribbon cable in place.
Pull the white ribbon cable towards you to remove it.
Use tweezers to remove the connector that has the blue, red, black, and white wires.
Use a plastic opening tool to pry the laptop's upper casing off of its lower casing. Move the opening tool around the sides of the case to help separate them.
Use a Phillips #1 screwdriver to remove the four 6-mm screws from the two hinge pads that secure the display assembly to the lower laptop section.
Use tweezers to remove the following two connectors:
One of the connectors has one black and one white wire.
The other connector has black, green, red, yellow, and white wires.
Use your fingers to remove the following connector:
The connector is large and is located at the top right corner of the motherboard, as shown.
Using the Phillips #1 or Phillips #00 screwdriver, remove the two 3-mm screws from the card with black and white wires coming off of it.
Gently remove the card with your fingers.
Remove the power jack connector.
Remove the connector that has one red wire and one black wire.
Remove the connector with red, yellow, green, white, and black wires.
Remove the large connector near the fan.
Gently pull the power jack cable and socket out of its housing. It should come out entirely.
Gently push the two black tabs until they stop moving.
Gently pull the silver ribbon cable out of the connectors.
Use a Phillips #00 screwdriver to remove the two 3-mm screws from the card connected to a black wire.
Use your hands to gently lift the top right side of the motherboard. Then, pull it upwards to the right and away from you.
