Введение
Use this guide to replace the processor. This may be necessary if the screen is black when the computer is on if the cause of the problem is not the screen.
Выберете то, что вам нужно
Place the laptop upside-down with the display hinges facing away from you.
Slide the latch for the right battery bay to the right and hold.
Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
Remove the battery.
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
Slide the hard drive to the left using your fingers.
Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
Pull the RAM card away from the computer.
Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
Insert the plastic opening tool at either end of the strip.
Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
Pry the top of the keyboard loose from its casing using a plastic opening tool.
Gently push the two tabs locking the black ribbon cable.
To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
You may now safely separate the keyboard from the laptop.
For the following steps, use a Phillips #1 screwdriver.
Remove the twelve 6-mm screws that border the bottom of the laptop.
Remove the 6-mm screw located in the lower middle of the device.
Remove the three 3-mm screws located in the battery bay.
Remove the one 4-mm screw located near the RAM.
Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
Separate the laptop upper casing from the lower casing by using an opening tool around the sides of the case to pry it apart.
Remove the four 6-mm screws from the two hinge pads using a Phillips #1 screwdriver.
Инструмент, используемый на этом этапе:Tweezers$4.99
For the following steps, use tweezers:
Remove the connector equipped with the black and white wire.
Remove the connector equipped with the black, green, red, yellow, and white wires.
Using your fingers, remove the large connector located at the top right corner of the motherboard, as shown.
Remove the two 3-mm screws from the card equipped with black and white wires by using a Phillips #00 or Phillips #1 screwdriver.
Gently remove the card with your fingers.
Remove the power jack connector.
Remove the connector equipped with one red wire and one black wire.
Remove the connector equipped with red, yellow, green, white, and black wires.
Remove the large connector near the fan.
Remove the power jack cable and socket from its housing by pulling gently.
Gently push the two black tabs until they stop moving.
Remove the silver ribbon cable from the connectors by pulling gently.
Rremove the 6-mm screw near the hard drive using a Phillips #1 screwdriver.
Remove the two 3-mm screws from the card connected to the black wire using a Phillips #00 screwdriver.
Gently lift the top right side of the motherboard. Pull it upwards to the right and away from you.
Flip the motherboard over. Remove the two 3-mm screws from the fan using a Phillips #1 screwdriver.
Remove the housing equipped with red, blue, and yellow wires using your fingers.
Using a Phillips #1 screwdriver, remove the two 3-mm screws locking the heat sink in place.
4 участников успешно повторили данное руководство.
Один комментарий
Although my Toshiba Laptop was not exactly the same it was close enough to be able to do all that was required. The fan and heat-sink were completely clogged and it caused an over-temp condition that would shut down the laptop. After removing and cleaning the fan etc. it now runs fine. It would have been a much riskier endeavor if you had not made such detailed instructions. Thank you.
