Введение
In this guide you will learn how to remove and replace the keyboard for the Toshiba Satellite L305-S5955 laptop.
Выберете то, что вам нужно
Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
Lift the keyboard up and locate the ribbon.
Gently pull the ribbon out of its compartment to release it from the motherboard.
2 участников успешно повторили данное руководство.
