Введение
If your keyboard needs a thorough cleaning or needs a replacement, this is the guide you’re looking for. This guide will show you how to safely remove your keyboard from the computer’s shell.
Выберете то, что вам нужно
The plastic strip boxed in red is located above the keyboard of the computer.
There are three points of contact boxed in red needed to release located at the far left, the far right and the middle of the plastic strip.
Remove the plastic strip from one far end progressively towards the other end using a metal spludger.
Use the metal spludger to push the keyboard in the direction of the track pad and then lift the keyboard up.
There are two tab boxed in red is located at each side of the ZIF (zero insertion force) connector.
Use a metal spludger to push the tab upward in order to release the cable ribbon.
Carefully pull out the ribbon cable from the ZIF (zero insertion force) connector.
