Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will cover the access to and removal of the hard disk drive for replacement.
Выберете то, что вам нужно
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Remove the cover by lifting the right side up at an angle before removing the entire cover.
Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
