Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the two sliding battery locks on the underside of the laptop.
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
Lift up the top of the keyboard to remove it.
Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
Unplug the ribbon cable from the laptop.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
Unplug the wires highlighted with red squares.
Using a pry tool and yours hands to remove the motherboard cover.
