Введение
The hard drive is the memory center of your computer. It stores all of your information and files and allows you able to access that data. Replacing the hard drive can speed up your computer and improve the hard drive storage space.
Выберете то, что вам нужно
Use a J1 screwdriver to unscrew the two circled screws. The screws will remain attached to the plastic panel.
Lift the panel and remove it from the laptop.
Slide the hard drive to the left to detach it from the computer.
Lift the hard drive from the computer.
