Введение
The laptop screen is one of the most important parts of the laptop. If its screen is damaged, it can impair your usage of your laptop. Replacing the screen can fix any visual problems you have.
Выберете то, что вам нужно
Use a spudger to pry up the plastic panel between the keyboard the screen.
Repeat on opposite side of laptop.
Tilt the laptop's screen back.
Lift the panel and remove it from the laptop.
Unclip the keyboard from the laptop by lifting it.
Slide the keyboard slightly towards the screen.
Lift the keyboard out of the way.
Unscrew the two circled screws with a J1 screwdriver. The screws will remain attached to the plastic panel.
Gently lift and detach the grey and black antennae cables that are attached to the blue circuitboard.
Flip the laptop over.
Pull the black and grey cables out of the laptop, towards the laptop screen.
