Введение
The keyboard is subject to some of the most abuse experienced by a laptop. Whether it is from over use or even water damage, the keyboard can stop working. With the removal a couple screws and the release of a few tabs, the keyboard can be replaced with little effort.
Выберете то, что вам нужно
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the two screws holding the keyboard in place.
Two 5.7 mm Phillips screws.
There are three tabs holding the keyboard in place.
They are located under the ESC, F8, and DEL keys.
Expose the tabs by pressing down on adjacent keys.
While you press down the ESC key, push the tab with the spudger to release that side of the keyboard.
Use a finger to prevent the keyboard from locking back in place.
Repeat the previous step for the tabs under the F8 and DEL keys.
Pick up the keyboard. This exposes a cable that connects the keyboard to the laptop.
Gently unplug the ribbon cable connecting the keyboard to the laptop by pulling horizontally.
3 участников успешно повторили данное руководство.
