Введение
The LCD display can be easily separated from the laptop body to allow for replacement if it is damaged or functioning improperly.
Выберете то, что вам нужно
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
With the aid of a plastic removal, disconnect the two wires attached to the wireless card.
Remove the two screws on the back side of the laptop holding the LCD display in place.
Two 8.5 mm Phillips screws.
Remove the final two screws on the bottom side of the laptop holding the LCD display in place.
Carefully pull apart the LCD display from the base by pulling vertically upwards on the display.
3 человек успешно провели ремонт по этому руководству.
