Введение
The wireless card allows the user to wirelessly connect to the internet if Wifi is available. If you are experiencing trouble with your wireless connection, replacement of your wireless card may be necessary. Following the this guide will allow you to easily replace your wireless card.
Запчасти
Никакие детали не требуются.
  1. Make sure the battery lock switch is switched to the unlocked position.
    • Make sure the battery lock switch is switched to the unlocked position.
      • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Slide the battery release switch to the left.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
    • Use a finger to remove the panel by lifting up on the provided removal tab.
    • Remove the black and the white antenna wires attached to the wireless card.
    • Using a plastic removal tool, gently pop the connections apart.
    • Remove the screws holding the wireless card in place.
      • Two 3.6 mm Phillips screws.
    • The wireless card will automatically pop up allowing for easy removal.
    • Pull to remove the wireless card.
Заключение
Stephen Sippel
Участник с: 16.04.2013
167 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 21-54, Johann Spring 2013 Member of Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
4 членов
Автор 9 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 5
За всё время: 1,549
