Введение
The wireless card allows the user to wirelessly connect to the internet if WiFi is available. If you are experiencing trouble with your wireless connection, replacement of your wireless card may be necessary. Following the this guide will allow you to easily replace your wireless card.
Выберете то, что вам нужно
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the black and the white antenna wires attached to the wireless card.
Using a plastic removal tool, gently pop the connections apart.
Remove the screws holding the wireless card in place.
Two 3.6 mm Phillips screws.
2 человек успешно провели ремонт по этому руководству.
