Введение
We will be demonstrating how to replace the hard drive located on the upper right hand side of the laptop. This is where the computer stores everything for your Toshiba Satellite L455-S5046.
Выберете то, что вам нужно
Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
Insert your finger under the middle tab and lift the battery out.
Locate the hard drive in the upper right corner on the back of the computer.
Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
