Введение
In this guide we will teach you how to replace the keyboard of your laptop.
Выберете то, что вам нужно
Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
Remove the keyboard slowly. It will be attached to the laptop by a plastic connector, which can be disconnected from the laptop by pulling gently.
