Введение
In this guide we will instruct you on how to change the optical drive of your laptop. This will be helpful if yours is broken.
Выберете то, что вам нужно
Видео обзор
Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
The optical drive is partially visible and push it to the right.
The optical drive should pop out on the right side, and you can gently pull it out.
