Введение
This guide is useful for replacing a broken keyboard on your laptop. In this replacement guide, you will remove the old keyboard and install the new one.
Note: Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
Инструменты
Запчасти
Никакие детали не требуются.
Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
Disconnect the keyboard cable that is still attached to the keyboard (Red).
Unlatch the fastener (green).
Using your hands, pull the keyboard connector out, not up.
