Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The optical drive is what reads a CD or DVD when placed in the drive. To replace it, follow the steps outlined in this guide.
Выберете то, что вам нужно
Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
To remove the hard drive case, first pull the black tab to the right.
Then pull the black tab up to remove the case.
Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
Lift up the plastic panel and carefully disconnect the red and white ports.
Remove the panel
Turn the laptop over so the bottom is facing up
Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
Turn the laptop back over so the motherboard is facing up
Now slide the optical drive out of the computer by gently pulling it to the right
2 участников успешно повторили данное руководство.
