Введение
The removal of the hard drive is a multi-step process which is simplistic at first glance, but can present a challenge if instructions are not carefully followed.
Выберете то, что вам нужно
Unscrew the screw using a Phillips #1 screwdriver.
Lift and remove the cover from the device.
Unscrew the circled screw and set it aside.
With the laptop oriented with the battery at the top, slide the hard drive component to the left until it clicks.
Gently lift up to remove the hard drive from its compartment.
Еще один человек закончил это руководство.
