Toshiba Satellite L505D-GS6000 RAM Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite L505D-GS6000 RAM Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite L505D-GS6000 RAM Replacement, Battery: шаг 1, изображение 2 из 2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 RAM Replacement: шаг 2, изображение 1 из 1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 RAM Replacement, RAM: шаг 3, изображение 1 из 2 Toshiba Satellite L505D-GS6000 RAM Replacement, RAM: шаг 3, изображение 2 из 2
    • Place the laptop upside down so the bottom is facing up and the side that opens is facing you.
    • In the middle of the laptop there is a panel held down by one 6 mm screw, remove that screw using a Phillips #0 screwdriver.
    • Place the screw down in a place that you will not lose it.
    • Remove the RAM cover.
  4. Toshiba Satellite L505D-GS6000 RAM Replacement: шаг 4, изображение 1 из 2 Toshiba Satellite L505D-GS6000 RAM Replacement: шаг 4, изображение 2 из 2
    • The unlock the RAM push out on the metal pieces touching the RAM on the bottom and top side until it clicks
    • Once you do that gently slide the ram out and place it to the side.
    • Be gentle as to not damage any of the pieces within the laptop, excessive force could break the RAM slots and require more repairs.
  5. Toshiba Satellite L505D-GS6000 RAM Replacement: шаг 5, изображение 1 из 2 Toshiba Satellite L505D-GS6000 RAM Replacement: шаг 5, изображение 2 из 2
    • You’ll need to do the same as the top for the bottom set of RAM, so gently push outward on the metal pieces above and below the RAM.
    • Again be gentle when following these steps as you could could cause more damage than you’re able to fix.
    • Gently slide the RAM out from the slot.
Заключение
Еще один человек закончил это руководство.
Adam Dellicker
Участник с: 03/19/18
539 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team S4-G2, Covino Spring 2018 Участник UMass Dartmouth, Team S4-G2, Covino Spring 2018
UMASSD-COVINO-S18S4G2
2 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 392
