Введение
This guide shows how to remove and replace the lithium-ion battery for the Toshiba L55 laptop. If your battery is swollen, take appropriate precautions.
Выберете то, что вам нужно
Flip the laptop over so that the back cover is facing up.
Unscrew the captive Phillips screw securing the RAM cover.
Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
Disconnect the cable.
Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
Slide the drive out of the bay and remove it from the laptop.
Insert the point of an opening pick into the back cover seam near the ethernet port.
Twist the pick to release the plastic clips along the edge.
Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
Remove the back cover.
Remove the two 6.8 mm long Phillips screws securing the battery.
Lift the battery out of its recess and move it slightly away from the motherboard in order to reveal the battery cable.
Grasp the battery cable near its motherboard socket and pull the connector horizontally out of the socket.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
