Toshiba Satellite L55W-C5256 Hard Drive Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite L55W-C5256 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 5, изображение 1 из 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 Hard Drive Replacement, Hard Drive: шаг 7, изображение 1 из 2 Toshiba Satellite L55W-C5256 Hard Drive Replacement, Hard Drive: шаг 7, изображение 2 из 2
    • Flip the white part of the hard drive cable connector up.
    • Gently pull the cable out.
  8. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 8, изображение 1 из 1
    • Lift the hard drive from the device.
  9. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 9, изображение 1 из 2 Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 9, изображение 2 из 2
    • After removing the hard drive, remove the connection cable.
    • Set the connection cable aside for use with your replacement hard drive.
  10. Toshiba Satellite L55W-C5256 Hard Drive Replacement: шаг 10, изображение 1 из 1
    • Remove the protective blue rubber caging from the hard drive.
    • Be sure not to damage the blue rubber caging during removal. This protective caging prevents your hard drive from moving freely inside your device, and will be needed for reassembly.
Заключение
5 участников успешно повторили данное руководство.
Jennifer
Участник с: 09/23/19
777 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team S1-G5, Virtue Fall 2019 Участник Western Carolina University, Team S1-G5, Virtue Fall 2019
WCU-VIRTUE-F19S1G5
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 22
За всё время: 730
