Toshiba Satellite L55W-C5256 RAM Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite L55W-C5256 RAM Replacement, Battery: шаг 1, изображение 1 из 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 RAM Replacement: шаг 2, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 RAM Replacement: шаг 3, изображение 1 из 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 RAM Replacement: шаг 4, изображение 1 из 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 RAM Replacement: шаг 5, изображение 1 из 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 RAM Replacement: шаг 6, изображение 1 из 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 RAM Replacement, RAM: шаг 7, изображение 1 из 3 Toshiba Satellite L55W-C5256 RAM Replacement, RAM: шаг 7, изображение 2 из 3 Toshiba Satellite L55W-C5256 RAM Replacement, RAM: шаг 7, изображение 3 из 3
    • Reminder: Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Using your forefinger, gently pull on the left bracket that secures the RAM to the motherboard.
    • Using your forefinger, gently pull on the right bracket that secures the RAM to the motherboard.
    • When successfully freed from the locking brackets, the RAM stick will "pop up" at a 45-degree angle.
    • Lift the RAM stick from the motherboard.
  8. Toshiba Satellite L55W-C5256 RAM Replacement: шаг 8, изображение 1 из 1
    • Repeat step 7 to remove the second RAM stick.
    • When replacing the RAM sticks, re-insert them at the same 45-degree angle at which they were removed.
Заключение
2 участников успешно повторили данное руководство.
Jennifer
Участник с: 09/23/19
777 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team S1-G5, Virtue Fall 2019 Участник Western Carolina University, Team S1-G5, Virtue Fall 2019
WCU-VIRTUE-F19S1G5
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 373
