Введение
This guide will instruct you how to replace your Toshiba Satellite camera.
This will fix:
  • A broken video chat camera
  • A broken microphone
Запчасти
Детали не указаны.
  1. Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws. Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side. Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry. Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable. Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Carefully disconnect the camera board from the laptop. We used tweezers. Carefully disconnect the camera board from the laptop. We used tweezers.
    • Carefully disconnect the camera board from the laptop. We used tweezers.
Заключение
Еще один человек закончил это руководство.
Robby
Участник с: 04.02.2013
52 Репутация
1 руководство автора
Команда
Cal Poly, Team 7-7, Maness Winter 2013 Участник Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 2,219
