Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: шаг 1, изображение 1 из 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: шаг 1, изображение 2 из 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: шаг 1, изображение 3 из 3
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: шаг 2, изображение 2 из 2
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: шаг 3, изображение 1 из 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: шаг 3, изображение 2 из 2
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: шаг 4, изображение 1 из 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: шаг 4, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Carefully disconnect the camera board from the laptop. We used tweezers.
Заключение
Еще один человек закончил это руководство.
Robby
Участник с: 02/04/13
52 Репутация
1 руководство автора
Команду
Cal Poly, Team 7-7, Maness Winter 2013 Участник Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 20
За последние 30 дней: 24
За всё время: 2,668
