Введение
Replacing the keyboard is an intermediate level repair. Following the instructions carefully will help you successfully replace your keyboard.
Выберете то, что вам нужно
Locate the battery locks on the bottom of the laptop.
Slide the right lock outwards, until it locks into place.
Slide and hold the left lock outwards and hold it in place.
Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
5 участников успешно повторили данное руководство.
2 Комментариев
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
