Выберете то, что вам нужно
Locate the battery locks on the bottom of the laptop.
Slide the right lock outwards, until it locks into place.
Slide and hold the left lock outwards and hold it in place.
Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Remove stickers from four corners of laptop.
Remove screws underneath stickers.
Use plastic opening tool to pry the hinges off.
Remove the screen cover.
Unscrew the six screws on the bottom of the screen near the top of the hinges.
Remove cable located next to the fan.
Fold down screen without screen back cover to remove cable as shown.
2 участников успешно повторили данное руководство.
