Введение
After going through the Troubleshooting guide, and you hear that your laptop is "clicky" or that the hard drive is not connect, this guide will guide you through the removal of the hard drive.
Выберете то, что вам нужно
Flip the laptop upside down. Locate the two latches on both sides of the battery.
Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
Simultaneously slide the latch on the left outwards while pulling the battery towards you.
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
Work your way around the border of the panel, releasing the rest of the clips.
Once all clips are released, lift the cover up and pull towards you.
Slide the hard drive to the left, using the silver tab.
Pull up the silver tab, removing the hard drive from the slot.
To install a new Hard Drive, follow these instructions in reverse order.
2 участников успешно повторили данное руководство.
