Введение
If your Toshiba Satellite L755-S5244 disk drive is not reading disks, then it should be replaced. The removal of or the replacement of the disk drive will require this guide.
Выберете то, что вам нужно
Pull keyboard up and partially out.
Detach conductor ribbon.
Slide keyboard out completely.
Remove the seven 4mm Phillips #0 screws beneath the keyboard.
After the screws are removed, remove the face plate to reveal the motherboard.
Lift up the flap and there will be two 2 mm Phillips screws beneath that will need to be unscrewed to pull the disk drive out.
Now the disk drive will be able to be removed from the motherboard by sliding the drive to the right.
Еще один человек закончил это руководство.
