Введение
If your hard drive has been damaged or simply want to upgrade storage space, it can be replaced with nothing other than a Phillips screwdriver. This replacement is quick and no electronic skills are necessary to succeed.
Выберете то, что вам нужно
Remove the single 3mm Phillips #0 screw securing the hard drive (hard drive not pictured).
Once the screw is removed, push the hard drive up (away from the battery) to disconnect it from the laptop.
You are now able to lift the hard drive out of the laptop.
