Введение
This guide will help readers replace the fan which can stop working over time.
Выберете то, что вам нужно
Push the latch on the right to the right to unlock the battery latch locking mechanism.
Push the battery latch on the left to the left to unlock the battery.
With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
The battery will come free.
Turn the laptop over to place it top down.
Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
Lift the back plate off the laptop, exposing the RAM and Hard Disk.
Rotate the laptop so that you have access to the optical drive.
Remove the drive.
Unscrew the hard drive.
Carefully push the hard drive away from its port. This should not require substantial force.
Lift the hard drive out.
Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver.
Unplug the fan's connection to the motherboard.
Lift the fan from the laptop.
Use a soft cloth to clean the dust away from where the fan was.
Еще один человек закончил это руководство.
