Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
  1. Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Remove the back panel.
  2. Locate the two clips holding the RAM chip in place. Apply pressure to each clip, pulling them away from the RAM. One end of the RAM will pop out.
    • Locate the two clips holding the RAM chip in place.
    • Apply pressure to each clip, pulling them away from the RAM.
    • One end of the RAM will pop out.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Gently pull RAM out as shown. Gently pull RAM out as shown.
    • Gently pull RAM out as shown.
  5. To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • Gently push down on the RAM chip until it snaps securely into place.
Заключение
Michael Jensen
Участник с: 18.04.2011
417 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 4-3, Regan Spring 2011 Участник Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 2,572
