Введение
This guide will show you how to replace your keyboard.
Инструменты
Запчасти
Детали не указаны.
Carefully pry the panel above the keyboard from both sides of the laptop using the iFixit opening tool.
Push back the screen until it is horizontal with the laptop.
Gently remove the clips that connect the panel to the screen.
Remove the two screws using a Phillips #1 screwdriver.
Gently pry the keyboard from the laptop using the iFixit opening tool.
Slowly lift the keyboard away from the laptop until you are able to remove the ribbon that connects to the laptop.
5 участников успешно повторили данное руководство.
