Введение
This guide will illustrate how to replace your optical drive.
Инструменты
Запчасти
Детали не указаны.
Remove the ODD screw with a #1 Phillips head screwdriver as indicated in the picture.
Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot.
Почти готово!
Заключение
