Введение
Learn how to replace your laptop's RAM.
Выберете то, что вам нужно
Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
Then, use a the blue iFixit Opening Tool to pry the cover panel off.
Push on to the RAM tabs to disconnect the RAM form the device.
The RAM will pop off from the socket. Gently pull the RAM out of the socket.
3 человек успешно провели ремонт по этому руководству.
