Введение
This guide will be referred to for other steps because disconnecting the power to your computer is crucial to do before working on it. There are two spring-loaded switches that lock the battery into place.
  1. Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
    • Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
    • Slide the unlock switch in the top left-hand corner to the left/unlock position.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Hold the switch in upper right-hand corner to the right.
    • Hold the switch in upper right-hand corner to the right.
    • With the switch held open, pull the battery straight away from the laptop.
Заключение
Matthew Trinh
Участник с: 31.01.2013
63 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 7-11, Maness Winter 2013 Member of Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 1
За 30 дней: 2
За всё время: 464
