Введение
The purpose of this guide is to demonstrate the process of removing a Toshiba Satellite M55-S135 laptop keyboard. For this process you'll need a flat-head screwdriver and a Phillips #00 screwdriver.
Выберете то, что вам нужно
Locate the vertical seam between the speakers and the top row of keys on the keyboard.
Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
Disconnect the keyboard cable.
