Toshiba Satellite P105-S6024 LCD Display Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite P105-S6024 LCD Display Replacement, Accessing the Bezel: шаг 1, изображение 1 из 1
    • Before you do anything, make sure the AC adapter is unplugged and the battery removed from the laptop.
    • There will be 4 rubber grommets on the plastic bezel surrounding the screen, 2 square and 2 circular. You will have to pry these out or remove them somehow. They are small so set them aside where you will be able to find them later.
    • The grommets are held in their bores by adhesive. If upon reassembly they do not stick in their bores, attach a small amount of glue to keep them in.
    • Directly behind the grommets will be 4 Phillips screws holding the bezel to the screen. These can be removed with a Phillips #00 screwdriver. As with the grommets, put these in a safe place where you can find them later.
  2. Toshiba Satellite P105-S6024 LCD Display Replacement, Accessing the Display Assembly: шаг 2, изображение 1 из 2 Toshiba Satellite P105-S6024 LCD Display Replacement, Accessing the Display Assembly: шаг 2, изображение 2 из 2
    • GENTLY pull the bezel off. I used a small flat-blade screwdriver out of a glasses repair kit to do this. First I gently pried the bezel corners to loosen them, then slowly worked my way around, carefully tugging and pulling the bezel out of the plastic locks.
    • After you have the bezel off, there will be 4 Phillips screws on each side of the screen, near the edges (the picture shown here only shows 1 side). Again, use a Phillips #00 screwdriver to remove them.
  3. Toshiba Satellite P105-S6024 LCD Display Replacement, Display Assembly Removal: шаг 3, изображение 1 из 3 Toshiba Satellite P105-S6024 LCD Display Replacement, Display Assembly Removal: шаг 3, изображение 2 из 3 Toshiba Satellite P105-S6024 LCD Display Replacement, Display Assembly Removal: шаг 3, изображение 3 из 3
    • At this point, the screen assembly will be free to move. Gently pull it out and lay it on the keyboard.
    • You may wish to lay a cloth on the keyboard for increased protection of the screen and keyboard.
    • Near the bottom-right of the screen will be a connector which is secured with clear tape. Remove the tape, pull the cable gently out of the connector and set it to the side.
    • You may find it helpful to fold the tape up (as shown in the third picture) so it doesn't stick anywhere else
  4. Toshiba Satellite P105-S6024 LCD Display Replacement, Disconnecting Display Cables: шаг 4, изображение 1 из 3 Toshiba Satellite P105-S6024 LCD Display Replacement, Disconnecting Display Cables: шаг 4, изображение 2 из 3 Toshiba Satellite P105-S6024 LCD Display Replacement, Disconnecting Display Cables: шаг 4, изображение 3 из 3
    • At the top of the screen, near the center will be the inverter. On the left is the power cable and on the right is the backlight power source.
    • Power supply
    • Backlight power source
    • Carefully pull the connectors out of the inverter. Do not pull on the wires, only the plastic connector. It may take a bit of maneuvering to get a solid grip on them.
    • Holding the power supply and video cable in place are two strips of tape. Carefully peel them off, and then lift the cables up. The old screen can now be removed and the new screen installed.
    • Upon reinstallation the cables must be taped down again. If the original tape no longer holds, you can use masking tape.
Заключение
3 участников успешно повторили данное руководство.
Jacob Micallef
Участник с: 03/06/17
993 Репутация
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 716
