Введение
This guide will take you through the steps of replacing your battery. You can use these to replace a malfunctioning battery for a new, working battery.
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Slide and hold the tab on the right side of the battery to the right.
While holding the right tab, slide the battery upward and out its socket.
