Введение
This guide will show you how to replace the fan in your Toshiba satellite. The fan keeps the computer cool when running. Be careful when removing the fan because the heat sink may detach from it.
Выберете то, что вам нужно
Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
Using tweezers, disconnect power cable by gently pulling white end out from its socket.
Еще один человек закончил это руководство.
