Введение
Be careful to handle this device with care while performing this guide make sure to use use an anti-static wrist strap.
Выберете то, что вам нужно
Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
Disconnect the hard drive from the mother board by gently pulling out the black connector.
2 участников успешно повторили данное руководство.
Один комментарий
Can you change the touch panel of toshibasatelliteP50W-B1038.
