Toshiba Satellite P55-A5312 Battery Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite P55-A5312 Battery Replacement, Battery: шаг 1, изображение 2 из 2
  2. Toshiba Satellite P55-A5312 Battery Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite P55-A5312 Battery Replacement: шаг 2, изображение 2 из 2
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: шаг 3, изображение 1 из 1
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: шаг 4, изображение 1 из 1
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the battery from the laptop after it has been completely disconnected.
Заключение
5 участников успешно повторили данное руководство.
ohatae
Участник с: 01/25/17
294 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-1, Banghart Winter 2017 Участник Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 членов
Автор 6 руководств
Один комментарий
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 22
За всё время: 5,823
