Введение
Replacing a broken or damaged battery can increase the lifespan of your laptop and improve performance. In this guide we will show you how to replace your Toshiba Satellite battery. We will first open the back of the laptop. After, we will carefully unscrew and remove the battery for replacement.
Выберете то, что вам нужно
Remove the bottom cover of your laptop. For instructions on how to do this, take a look at the Toshiba Satellite P55-A5312 Back Cover Removal Guide
Locate the battery, which is in the top right hand corner of the laptop.
Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
Locate the intersection of the wires that connect the battery to the motherboard.
Unplug these wires by gently pulling on the white plug, as shown in the picture.
Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
Move the speaker elsewhere while replacing the battery (do not disconnect it).
5 человек успешно провели ремонт по этому руководству.
Один комментарий
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
