Введение
Use this guide to remove the Toshiba Satellite P55t-A5116 battery.
Выберете то, что вам нужно
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Gently pry off the bottom case with the plastic opening tools.
Find the seam between the back case and the rest of the laptop casing.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
12 участников успешно повторили данное руководство.
9 Комментариев
The screws for the battery are in very tight and I'm having trouble unscrewing them
I'm having difficulty unplugging the 10 pin connector. Afraid if I pull too hard it will pull the wires out. Any suggestions?
Just wiggle it back-and-forth a bit and it should come out. I just change my own battery.
